Got two 12" level 4s with essentially level 5 softparts. Would this enclosure be good for them? Want it tuned at 32 for a daily groundpounder. Powered by a saz2500 at 1 ohm. Want the box to be strong enough for 2 xl's as i plan on upgrading in the future. Want it to be like the pic on the first post labeled 0 common walls with the square port in the middle. Will be sealed off and firing into the cabin of a 04 chrysler 300m.
Not nearly enough volume..
And not even close on the vent
Need more like 4cuft net
And 50-60sqin of port
Ive been told 1.5 per sub would be good so i made it a little bigger to account for displacment of subs and bracing.....
I will fix the port tonight.
i'd listen to ray dude. he has probably installed more subwoofers than you have years in your life.
what he said, looks more like a box for some 10s to me
I've built a 3.04 cubic foot box for my LVL 4 12's and it was a little small, next one is over 3.5. They like air space, and if you're going to use sketchup use the real dimensions so you have a better feel for how it'll look cause your front baffle would be 12.5 in that drawing and the sub cutout holes to flush mount have to be 12.75 or larger.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
I'm putting me lvl 4s in 3.6 cubes
2006 Nissan Z Track.
My Feedback Thread
how are they "essentially" level 5 soft parts lol?
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
