AQ3500.1
do you have the big 3 already done and are you looking into a high-out put alt?
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
good suggestion, and WRONG, you dont need a damn h/o alt for 3500 watts unless you have a whimpy 90amp alt, my AQ runs just fine at 1ohm on a stock alt, and thats only with 1 extra battery, that being a kinetic 1400, but inall youll really only need 1-3 batterys, depending on how big your stock alt is, big3 is a must! 0g is also a must!
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
Yeee
Refs-(b.f.) 99vic, WCA Rusty(x3) Nathan@XSPOWER, Ampjunkielikeme, Bread0710, AmiCreations (s.t.) REsLaPz, PandaGT(x2), Keiferacing, Juicemane (t.w.) Powski, Big gil[/center]
Build Log
http://www.stevemeadedesigns.com/board/topic/77726-sss-celica-dc-buildupdate-611-finished/
2005 subi STi 380whp 355whp
17" gold bbs
5% tint all around w/sunglare strip
JVC dvd double din
Knuconceptz 4ga wiring
XS Power!
Big 3
8" SAv2 d2
1800 audiopipe
Say it is a smaller stock alt wont having all thos batts running on the small alt burn it up faster?
2000 Grand Marquis
Digital Designs 9512
Rockford T2000bd1
At full tilt, no stock alternator can fully handle the current draw from that amp. Just saying.
This!
What they dont get is all their doing is draining and draining power form their batteries which isn't how to run an amp for daily.
To the OP get a H/O Alt 250+ amps and 2-4 optimas
Johns.jpgSuburban Coming Soon
This!
Thanks.
OP, does your truck have 2 batteries under the hood?
For the amp i would say for sure a quality H/O alt such as DC or Mechman, 1/0 all around including big 3, and at least 2-3 group 31 batts.
  • Who's Online   0 Members, 0 Anonymous, 1511 Guests (See full list)
