What frequency would you recommend for setting the iPod? And what DB I guess would be proper for a beginner to set at?
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
the same frequency you would use for your head unit and amps. might be smart after scoping it to run a sweep make sure all freq.s are clean too
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Posted (edited)
I would try both, ~45hz (because of subs) and 1000hz (because of mids and highs).
A sweep would be best though. It's more time consuming unfortunately.
Edited by hdorre
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Sounds good =] You're welcome.
LMFAO so true
:blush:
I have read to set your eq settings to flat and adjust the gains with till there is no clipping found with the o-scope. I have dont this and it seems find to me, but my question is why would you set your eq to flat and not adjust to your liking then adjust the gains to where there is not clipping?
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
I check mine with my current setting, if everything is fine, then adjust gains, if I have clipping then I adjust my eq to come to line with a clean signal. I don't listen to my eq at flat so why scope it there? I am not sure why you would just to have maybe a base point to start from.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
Reason to put the eq to flat is because you don't use a EQ to boost freqeuncies, only turn them down.
So if u are boosting freqeuncies you're doing it wrong. :peepwall:
If with my freq boosted my signal is clean, how is that doing it wrong all the eq is doing is changing the amplitude of the curve from the sine wave. It isn't adding distortion, well at max it is.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
