Wire all the coils in parallel, then wire the subs in parallel in pairs(now there are 3 pairs of dvc4s wired to 3 1 ohm loads). Then series them together aka 3 ohms.
Edited by I like kicker
R.I.P!
(Nov-29-2009)
92 explorer
current build
None of those would work, he needs a final load no less than 2 ohms.
with imp rise you'll be well over 2 ohms so 1.3 should be fine depending on the amp
R.I.P!
(Nov-29-2009)
92 explorer
current build
Guess he needs another amp?
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
70054345.png Edited by I like kicker
Correct. Like this:
Current system:
Previous systems:
  • Who's Online   1 Member, 0 Anonymous, 1757 Guests (See full list)
