more power bigger box lower Hz same spl?
Ephixx
i failed posted in the rong place T.T or did i
so im all noodin up the forum but i think this is an inportent question.
so im wondering i have 2 12's in a 2chamber 4cube box and i cant hit good lows (25-30Hz) and im wondering if i rebuilt the box bigger and uped the power a little will i get a better lowend (and proper port tuning)?
or just tune the box i have now lower then i want to play to get a better lowrange?
i edited the 4 times now because i dont want to look like a complete failer 4 not noing how this all works yet
Its harder to get high spl numbers at low freq. doing 150 db at 30hz is not at all the same as doing 150db at 50hz the latter is generally much easier
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
  • 3 weeks later...
Usually if you're gonna run more power to them than their RMS you're going to want to put it in a smaller box, and if you're running less in a larger box. Chances are you can't change your tuning easily on your box now, so go for a new design.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
  • Who's Online   0 Members, 0 Anonymous, 1887 Guests (See full list)
