Ok guys i have a dilema...i have a kicker L7 15" 2ohms... plan on wiring the voice coils in series to get 1 ohm... but im stuck on what amp i should use to power it... i was looking at kickers 1k watt 1 ohm amps but i just cant decide...would that be a good choice? any reccomendations would be much appreciated!!
just a suggestion...
I myself own a dc audio 175.4 amp and i love it. the quality is very good, only complaint is the settings for band pass since its directed toward subs, not door speakers which is no big deal to me but i love the quality and how well it performs. Maybe a dc audio 2k will do justice for you. They rate it at 2000 rms at 1 ohm which personally i think you should do because like everyone on here you will always get more subs/speakers and bigger and better stuff in the future and buying amps all the time is a pain. From what a friend of mine on here said is that dc amps are under-rated quite a bit. Now i did not have my 175.4 clamped so i cannot say off hand that they are but i can imagine they are under-rated.
And just to clarify, you are wiring them im parallel too. If both your coils on the sub are dual 2 ohms like you said then you would wire it in parallel to get a 1 ohm load (positive of voice coil 1 to the positive on voice coil 2, negative of vc 2 to the neg on vc1. Just wanted to make sure you were aware of that.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
yeah im going to wire them in parallel..not sure why i said in series....but money really isnt the problem and i dont want to buy a cheap amp..im looking for something that matches my sub...and no i wont get more subs or mono amps...this is going in my single cab truck and i can only fit 1 sub back there
