ur gonna have to rebuild your box. are you up to that first?
Yea of course. I have a prefabbed box a friend gave me , so I knew it was probably crap anyways. I mean it works decently and it looks clean but I like building my own.
alright. well to be honest this is my first time im building MY OWN box but i have learned a ton of things from the pros on here. im making my box for my single smd at 6.98 cubic feet for the gross volume and 5.48 cubic feet after the port volume. this is totally overkill for your subs tho. an enclosure that big in side is nonsense for your needs. ill try and figure one out for you. just give me a little time.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
Ok that would be great! Just keep in mind that I'll probably getting some big boys in the future... Fi car audio has really been getting my attention.
ok well first of all what series of the fi sub do you want to get? if anything i would stick to the future. building boxes sucks for all the time and effort and money it takes into building one that will do what you want it to.
Either 2 FI BTL or DC Audio lvl 4s. Either way I want a box capable of pounding out lows. So as long as it'll be tuned to approx 30Hz I'm sure it'll work with either subs
ok i just needed to know because ur current subs deff wont be able to handle being in a box that will be like sex to your ears with the fi's. what size fi are u getting?
Also do you have anything extra laying around in the back of your truck? any extra batts?? i would keep some room personally for some batts in the future. you never have enough power. lol
Yea I had the unfortunate experience of hearing 2 15 Fi btl's. Jesus christ, made my subs look like tweeters. I'm a 15 guy myself so I'll stick to that size.
Yea I have a good hook up on batteries and power goodies so that's not even a concern. When I stall my truck, I'll make the trip and take care of that subject.
I have a 2k watt amp for now but I'll just use that to tickle the subs until I wanna upgrade and utilize the benefits of properly powering them.
Just out of curiousity... Why would it make a difference if a box tuned to 30Hz contained my xtrpros or Fi Q or BTL's? Isn't a box tuned at that frequency just that? Excuse my ignorance
i figured you would ask. the difference is that the btl's are made for bigger enclosures thatn your xtr's. The sub has mechanical limits and if you exceed those limits you will kill the sub. for example if you put a AA SMD in a box that is the size of your current box it will be choking the hell out of it because a smaller enclosure means that your subs will be able to take more power (not a big difference tho in some cases) and not lose control. so theoretically you can have a btl in a 3 cubic foot box and be overpowering them with like 1k of power and they will still work like a champ but remember, the amp MUST have clean power if its any bit clipped ur screwing yourself.
So your xtr's will be geared to a smaller box than the fi sub will be using. its all about how much the woofer can displace air and all that stuff. its kinda hard to explain it so im sure someone else on here has a clearer way to explain it but pretty much your box for the xtr even if you were happy with the tuning you cannot use the fi's in it. you would be really straining the fi's because they love having bigger airspace to run.
Another thing to consider is that when you have subs that are very under-powered having a bigger box will compensate for that because its more air space that will create that "boom" affect of the sub hitting the notes even with low power. for example if you had the ability to make a subwoofer box and fit a component speaker in it, that would sound a hell of a lot louder in a bigger box than a smaller one to some extent.
I hope i didnt just blow up your brain.
and i forgot to mention, there are like 5 series of the btl. are u getting the n1, n2 or what series of it?
Nope, my brain is intact... Your basically saying a box built for the BTL's dimension wise will sound better than my current box even with the XTRPROS but I will not hear the major improvement until I put the BTL in it, which will be tuned exactly for the dimensions. AKA DITCH THE SHIT BOX , got it.
I was strongly considering the BTL N2 , I figure I'd never need more than that.
  • Who's Online   0 Members, 0 Anonymous, 579 Guests (See full list)
