Replacing a ignition switch
Removal (Lumina & Monte Carlo)
1. Disconnect negative battery cable. Remove steering column. See STEERING COLUMN . Remove hexagon washer head screws. On models with column shift, remove hexagon nut. Remove PRNDL adjuster bracket. Remove Torx washer head screws and dimmer switch mounting stud.
2. On all models, remove ignition switch assembly from ignition switch actuator assembly. See Fig. 5 or Fig. 6 . Disconnect electrical connectors as necessary.
CAUTION: If replacing ignition switch, new switch will be pinned in OFF-LOCK position. Remove plastic pin after switch is installed, or ignition switch will be damaged.
Installation
1. Ensure lock cylinder is in OFF-LOCK position. Place ignition switch slider in far right position, and then move one detent to left. See Fig. 7 . Insert a 3/32" drill bit into hole in switch to keep slider in position.
2. Install ignition switch assembly to ignition switch actuator assembly. To complete installation, reverse removal procedure. 3. Tighten screws and nuts to specification. See TORQUE SPECIFICATIONS .
Removal & Installation
1. Disconnect negative battery cable. Remove air bag module. See appropriate AIR BAG RESTRAINT SYSTEMS article. Remove steering wheel. See STEERING WHEEL . Remove left instrument panel insulator. Remove trim panel below steering column.
2. Push top of intermediate shaft seal down for access to upper intermediate shaft coupling and upper intermediate steering shaft pinch bolt. Remove upper intermediate steering shaft pinch bolt. Remove shift indicator cable end and casing from shift cam and A/T control indicator adjuster (if equipped). Disconnect park lock cable (if equipped).
3. Disconnect A/T range shift cable from ball stud on steering column. Depress 2 tabs and remove transaxle shift cable casing from steering column bracket.
4. Remove lower steering column bolts. While supporting column, remove upper column mounting bolts. Lower column to seat. Some servicing procedures may be performed with column in this position. Disconnect column electrical connector. Remove lower end of steering column shaft from upper intermediate steering shaft coupling. If necessary, use flat-blade tool to spread coupling clamp. Remove steering column.
5. To install, reverse removal procedure. Tighten upper and lower steering column mounting bolts to specification. Tighten steering column mounting bolts in sequence: right side lower bolt, left side lower bolt, left side upper bolt and then right side upper bolt. Tighten upper intermediate steering shaft pinch bolts to specification.
should be most of it. anything i missed, let me know. i can get it for you.
STEERING WHEEL
1. Turn ignition switch to OFF-LOCK position. Remove air bag module. See appropriate AIR BAG RESTRAINT SYSTEMS article. Mark steering wheel hub in relation to slash mark on steering shaft for installation reference. Loosen steering wheel nut, positioning it flush with end of steering shaft.
2. Using Steering Wheel Puller (J-1859-03, on Lumina and Monte Carlo; J 1859-A with J-42578 Legs, on Intrigue), pull steering wheel from shaft. Remove steering wheel shaft nut. Remove steering wheel from steering shaft. To install, reverse removal procedure. Tighten steering wheel shaft nut to specification. See TORQUE SPECIFICATIONS .
forgot this one. i will probably keep adding more as i find it on shopkey.
I just did one on my '96 W, they are a PITA. Wheel's gotta come off and all the bits for the horn and blinkers (and radio controls if so equipped) have to come out to get at ONE FUCKING SCREW!
BTW do as I say not as I do, MAKE SURE YOU PUT EVERYTHING BACK EXACTLY AS IT WAS! I have to redo mine as one fucking little plastic bit got put in wrong, so guess who has no horn? ME!
=@ =@ =@ =@ :bull: :bull: :bull: :bull: :bull:
Too many projects, too little time...
well as long as he follows those instructions he will be fine. that is specific for his exact car, not a generic, this might work. these are exact.
I had exact instructions as well but it sucks when you don't have pictures showing how everything goes back together. That's where I got tripped up.
