I used to own a ZR2 s10 and there is some really GOOD info about V8 and SAS for s10's on there forum ZR2USA.com this has been done hundreds of times over. There is even one guy on there with an LS1 in his.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
https://www.4wdfactory.com/store/products.php?product=Chevy-S%252d10-Solid-Axle-Hanger-Kit
Looks pretty simple, the cross-member they use is ugly as shit im sure you could make somethin a lil more show quality
Everythings in the attic or garage since the truck was sold last year. New build should be coming soon in a dodge cummins smile.gif
Yeah that's real simple, and yeah I think I could make a nicer cross-member, and its pretty cheap, I may just order that and make my own cross-member. Hmmm
thanks for the link
Look Into running mybe full size blazer front leafs, for the 44s run a 4:88 gear ratio would be best. If it was a 2wd orginally a 350 should drop right in. If you want to run lockers, I would choose selectable lockers, they will be more streetable. If you really wanted some low end torque run 5:13 gears. My dad is running 4:88s with 36" irocks on a Dana 60 in a jeep grand Cherokee with i6
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Right now the front d44 has 4.09s in it, not sure if I will leave them or not.
I am looking at a 350 right now, gonna go listen to it tomorrow after work, I just need mo monies haha
I agree the 4:88s should run nicely if you drop the 350 in there and you'll habe more acceleration from a stop. The swampers are great tires, they look really good and beefy on 16" or lower rims. I personally run 37" nitto mud terrains on a 20" rim, downfall on them they are super loud and are wearing pretty quickly. The positive is they pull and look really cool. I've heard good things from the toyo m/ts but theyre arent nearly as agressive lookin as the swampers. My .02
check out diy4x for brackets and other stuff. http://diy4x.com/cart/index.php?route=product/category&path=24
you are also going to need a passenger side flat top chevy knuckle for crossover steering. here's some info on what to look for.
http://www.google.com/url?sa=t&source=web&cd=1&ved=0CBwQFjAA&url=http%3A%2F%2F77cj.littlekeylime.com%2Fflatop_knucles.html&ei=5TV8TdCiB4GLrQHWy8HXBQ&usg=AFQjCNGoYQL_2DQo-ft7okq6a3xj7AH85Q
crossover steering, you will need a steering arm, you can make a drag link pretty easy using factory rod ends or you could use heim joints.
heres a steering arm. im using this same one on my fullsize chevy.
http://www.polyperformance.com/shop/Sky-Mfg-Dana-44-Standard-Height-Steering-Arm-p-19837.html
as for gearing, if you do re gear i'd go with 5.13's if you will be running an overdrive transmission(700r4 or 4l60e)
center console: lvl 4 12 1.75 cu ft tuned 37htz
alpine cda-9886
dc audio 120.4
infinity kappa 6.5" components
  • Who's Online   1 Member, 0 Anonymous, 1673 Guests (See full list)
