STEvil Posted March 4, 2011 Report Posted March 4, 2011 How did you get the 2.28? I did 13.5x13.5x25/1728? Is that right?..if I had a paypal or credit card I would but I don't have either(I'm 17 and in highschool) sorry 13.5x13.5x25 are the external dimensions, unless you told us the wrong numbers. You use internal dimensions for volume measurements. Port volume is subtracted from internal volume figures so you either build what you can or increase size a bit to make up for lost volume. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
chevyhoe08 Posted March 4, 2011 Report Posted March 4, 2011 ^^^^^ very correct. I will design something for you anyways. give me a little time. 2-18" Fi Btls 2-RF T2500-1bd box 14cu.ft after displacement tuned @ 32hz. Socal Box Designer/builder
Babyjuice Posted March 5, 2011 Author Report Posted March 5, 2011 Oh sorry no those are the internal deminsions, forgot to mention that.. Internal: 14.5Wx14Hx26D sorry re measured and found I could go a little bigger External:16Wx15.5Hx27.5D Should come out to like 3.05 cuft? BABYJUICE
Babyjuice Posted March 7, 2011 Author Report Posted March 7, 2011 Anybody have any tips on this...I'm still undecided BABYJUICE
R3nOSlaPP Posted March 7, 2011 Report Posted March 7, 2011 this is what i came up with 16 wide 26.5 long 15.5 tall its a 4inch slot port *port would be towards rear seats* Vehicle: 2017 Chevrolet Silverado High Country Electrical: 320A Singer Alt, (2) Limitless Lithium 15ah, Full Throttle FT680-48 Speakers: Stevens Audio SA 6 (ACTIVE), Audio Designs 3” Subwoofer: (4) B2 Audio XM 8’s Amplifiers: (2) B2 Audio Rage 2500.1, (1) B2 Audio Rage 1200.6 Processors: NavTv M650 (integration), Helix DSP Pro MK2 Silverado Build Log
Babyjuice Posted March 7, 2011 Author Report Posted March 7, 2011 Is that gross or net size? And would it work if I just flipped it upside down and had the subs downfire? Because I want to put my oem armrest on the box BABYJUICE
chevyhoe08 Posted March 8, 2011 Report Posted March 8, 2011 what f250 is this? single cab, crew cab...etc?? 2-18" Fi Btls 2-RF T2500-1bd box 14cu.ft after displacement tuned @ 32hz. Socal Box Designer/builder
