gianotti Posted September 17, 2007 Report Posted September 17, 2007 currently running: 180amp HO alt from ohio gen. 5 yellow tops, 2 18" BTLs off a HK 4000d modded, 8 runs of 0 gauge. just cant keep my voltage at steady says at 13v when im moving with the system up, and tries to stay at 12v when the system is playing when im sittin still. any recommendations......thanks guys
Slinky Posted September 17, 2007 Report Posted September 17, 2007 id say your gain is set too high or somethin. you should have a plenty strong electrical there. if you have the big 3 with all the other stuff you have ou should be fine. DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
ballin millenia Posted September 17, 2007 Report Posted September 17, 2007 maybe add another alt if anything Alpine IVA-W205 Hifonics XX-Hercules Hifonics XX-Jupiter O2 midranges 2 12" FI Qs 5 cube box tuned to 34 hz
kingsuv Posted September 17, 2007 Report Posted September 17, 2007 currently running: 180amp HO alt from ohio gen. 5 yellow tops, 2 18" BTLs off a HK 4000d modded, 8 runs of 0 gauge. just cant keep my voltage at steady says at 13v when im moving with the system up, and tries to stay at 12v when the system is playing when im sittin still. any recommendations......thanks guys I would double check your charging system. Even with a power hungry amp like that HK, You should see a better charge then that, unless your running it full tilt all day long. Designing, building, and shipping boxes. Yahoo IM - kingsuv00If the listening level is too loud, please inform the driver, so he can promptly pull over, and let you out. not many cars can get me to pluggin my ears but this one.......damn. I mean the first minute is ok but that thing just really starts digging deeper and deeper in your earhole till you cant stand it no more. Seems like it does it with relative ease....16 12's on 8 amps.........gotta love it.
dmanson Posted September 18, 2007 Report Posted September 18, 2007 either it what the other guys have said or that 180 alternator can't keep up with powering those big amps. i'd look into getting a bigger alternator or another 180 so you'll have a dual alternator setup. you're running alot of power and i know that 180 can't keep up. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
