sqsux Posted March 12, 2011 Report Posted March 12, 2011 So what would be " proper " electrical to run a AQ2200 at .5ohm? I run mine on stock electrical and an HC1400 at .5, I'm not saying this is safe but it's being done. Start out boxy, shape as you move along. Dc Audio Team Fur
fr34kout Posted March 12, 2011 Report Posted March 12, 2011 Run it at .5 just keep the gain relatively low. Just because you can run an amp all the way up to the point right before it clips doesn't mean you always should. In your case with the electricals you have now, just run it at .5 but go easy with the gain. That or set the gain correctly with your sub level at 0 then lower the sub level on your deck.
m1dg3thunt3r Posted March 16, 2011 Report Posted March 16, 2011 i actually called them today asking the same question, they told me 1400-1600 rms, but all the specs are slighty under rated by like 100 or 200 watts
Ricky A. Posted March 16, 2011 Report Posted March 16, 2011 i ran my aq 2200 at .5 ohms with no problems for about a year. it clipped like crazy until my electrical could handle it BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry156597298 Ford F-150Truck:37" superswamper tsl radials16" ion alloy wheels3" body lift2" suspension liftOffbrand brushguardPIAA driving lights6000K HID'sSystem:2 18" Sundown NightshaedAq3500Custom Fiberglass boxfosgate T1 6x8 Coxialsbass inferno 2000 watt 4 channel2 XS power d3100's0 Gauge
matt14 Posted March 16, 2011 Author Report Posted March 16, 2011 Yea i called earlier today also and they told me that if I were to run it at .5 ohm, it would void my warrenty but it can handle it from what they say- with good electrical 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
shogen Posted March 23, 2011 Report Posted March 23, 2011 scary thing running under 1 ohm load.... but if you got the bills to repair/replace it if it breaks... Enjoy! otherwise run it at 2 ohm and it should be fine IMO.... You don't necessarily need to max out the wattage of what a subwoofer can handle.... Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear) beaker- I know this sounds like a lot of anime bullshit, but it is true.
MrSoundz Posted April 21, 2013 Report Posted April 21, 2013 i actually called them today asking the same question, they told me 1400-1600 rms, but all the specs are slighty under rated by like 100 or 200 watts This is what I needed to know.
