I just bought a new single 12 inch Kicker CompVR 2ohm DVC with 400rms power. I wired up the sub in series when I put it in the box so wouldnt it be a 4ohm load on the amp now? I have an Alpine MRP-M500 monoblock amp. And it says in 2ohm it gives out 500x 1 watts rms and in 4 ohm it says it gives out 300x1. Is my wiring hooked up right?
Anybody??
i don't even understand your question..yes it is in series if you wired it right. and at 4 ohm.
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
lol i got confused myself
Sorry to confuse you guys! I wired the subs like the diagram shows on crutchfield in series so I was wondering if my amp is at 4ohm load now. But like you guys said its 4ohm. Thanks
if you wanted to have the amp see a 2 ohm load then you need (1) sub woofer with (4ohm) dvc's, so both coils will go together to be 2 ohms, with your current sub it will have to be wired in series to be (2ohm) + (2ohm) = 4 ohm final load, you need to get the other version of the subwoofer to get the power you want out of it, if you ever plan to do 2 subwoofers then you want the dvc 4ohm like you have
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
By wiring your 2 ohm dvc sub in series you bumped it up to 4 ohms. So if your amp puts out 300 watts rms at 4 ohms then that's how many watts your sub is getting.
Got Boom, what kind of watts are you looking to run to your CVR? I have mine running at 289w on my RF Punch 200.2, and it sounds plenty good enough for only costing me $100 for the whole setup (bought from a friend) :)
Hey Supercharged DD. thats nice u got it for cheap. lol im running 300watts on a alpine v-power mono block amp.
  • Who's Online   0 Members, 0 Anonymous, 7057 Guests (See full list)
