Rebuild - Blowthru to Walkthru!
Damn bro! I love this!
2004 Ford Mustang GTPioneer DEH-P7200HD head unitMach 460 Factory System
Cadence FXA1600.2
Cadence S2W10
Cadence 4 AWG wiring
Ported box, 2 cubes, 32 hertz
Valhalla - I saw how much you cut for your blowthrough. I only cut my hole 9" tall and like all the way across the cab. How big was your cut? Did the accordian boot fit that? I may have to do a bigger cut on mine cause my port always has to be really low! Do you have any pics of the original blowthrough? If so, could you send them to me? I was afraid to cut into the large cab brace(ledge)...did you notice any cab flex from that?
My original blowthru was large, about 44wide and 18 high. I do have pics somewhere ill try to find them and ill shoot them to you. The brace was completely cut out and yes i did get a HUGE amount of flex from it.
2009 Midwest SPL Nationals - Basic 4 - 1st place 154.5 @ 36hz
Team Sundown
Team SB Audio
Klade Turner
12 Sundown Audio SA-15s
4th order vertical clam
3 Sundown Audio 200.4's
Tsunami Wire
Kinetik 2400s
Youtube
Build Log - Blowthru to WALKTHRU!!!
watching for more, great job so far.
Are you going to add more to the sides of the box, looks like 1 layer only....? <_<
Steven :drinks:
Does this smell funny to you? Its your sister :roflmao:
Steven :drinks:
Yes there will be more reinforcing done to the sides. More pics will be coming and hopefully vids soon. -_- Ive been on the road busy the past week
Team Sundown
Team SB Audio
Klade Turner
Tsunami Wire
Kinetik 2400s
Youtube
Initial testing was done on 2 Sundown 3500d's
I was having a lot of problems with the vibration at the headunit. The HU kept shutting off at about mid volume, I could never turn it up. So I have set out to build a console for the HU to set on my tranny hump! Still rough, needs to be glassed and painted, and im probly going to add a couple neat little things to it but heres the general idea lol. It works great so far!
Wiring mocked up, will look clean, not sure whether to run wire under carpet or leave like this. Like this Ill have the versatility to use headunit outside of truck if needed. Hmmm choices choices.
Team Sundown
Team SB Audio
Klade Turner
Tsunami Wire
Kinetik 2400s
Youtube
Diggin' this man!!! Hey do you have a high output alternator? If so, what kind?? I can't seem to find one anywhere! What size engine is yours? Mines the 3.7L.
Float mounted IPad Mini playing through Bluetooth
IStreamer for Iphone or Ipad
Rockford Fosgate 3Sixty.3
RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors
Two Rockford T600-4's for the components
Blowthrough with two Sundown SA-8's
RF T1500-bd's for the subs
8000k H.I.D.'s in headlights and fogs
Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift)
17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's
Undercover Bedcover
Surco Roof Rack
Five Hella Lights on front bumper
270A Mechman Alternator
Two Optima Yellow Top batteries
Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
So you've been running those kinetiks for power? Which ones are those?
Undercover Bedcover
Surco Roof Rack
please go to your local sheet metal place and get something to cover that rear window of camper top would really suck to have someone break the glass and get them pretty amps
other then that shes looking loud
R.I.P!
(Nov-29-2009)
92 explorer
current build
Im actually looking into that, :) and yes that would really really really suck!
And thanks, i appreciate that.
Team Sundown
Team SB Audio
Klade Turner
Tsunami Wire
Kinetik 2400s
Youtube
