just get some welding wire its cheap and great wire
flexible too
R.I.P!
(Nov-29-2009)
92 explorer
current build
flexible too
Where can you find welding wire for cheap? The cheapest welding cable i can find costs like as much as knu's kollossus fleks which if theyre the same you might as well go with knu for their c/s
1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz7r.png
does any one know what kind of airspace i would be looking at for those btl's. because if the ia's need 18 cubes like in the vid on the page i wont be able to do them. id need to try to pull off the 2 18's in about 10 cubes
Edited by bass_stalker
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
flexible too
i got mine from welding supply store here in the city for like 4-5$ a foot i dont remember
i'm sure there is a bunch of people here on smd know websites to get cheap welding cable but i do not
R.I.P!
(Nov-29-2009)
92 explorer
current build
If you only got like 10 cubes you might wann think about runnin 15s. Cause after displacements with the 18 your not gonna be at 10 cubes anymore and I think that's a bit small for the 18s
Edit- just looked at the FI website and it says recommended ported enclosure for the btl n2 is 4.5-8 cu ft. So you may be alright afterall
Edited by glohubby05
id have to to look around some more. how do you guys feel about the ia dp 21 i know i could do it for sure in 10 cubes
flexible too
go to trystar.com or go on ebay and search for welding cable, find the one located in Minnesota i believe, the seller is coppercableman, that is trystars ebay account i believe, i bought my cable from coppercableman
its true welding cable, good stuff, pretty good on price, i bought 50ft for 153 bucks shipped, so about 3 bucks per ft, the more you buy im sure you will get a discount
you cna also choose what color you want and have whatever you want printed on the wire, for example my wire says "Noob at Work" on it a few times per ft
btw this will be my first system thats why i need a little bit of advice on what to choose
Are you going to be doing all of the install yourself? If you are then make sure you do alot of research here in the forums to understand what it takes to make a system like that happen. It isn't hard, just alot of things that go into making it right, otherwise your gonna spend alot more in replacing things and redoing things.
