Ok guys, i need your opinion on a couple of amps, I want to use one amp to power one Fi 15" Bl which is 1000 watts RMS Dual 1 Ohm
1. Which amp is better MA Audio HK1000D, or Hifonics BXi 1206D?
2. Also what other suggestions do you have for other 1000 watt RMS amps?
Thanks in advance :unsure:
Guest Nismofreak
well get a fully loaded one and put 1,600rms on it....
http://www.sonicelectronix.com/item_6336_H...+BXi+1606D.html
Posted (edited)
I like MA & Hifi theyre both really steady amps for what youre looking for, if price is not an issue then sonic has alot of choices of amps in that power range, anything from kicker, memphis, rockford or the jl/1000, on a budget i would go with MA or Hifi...
http://www.sonicelectronix.com/item_6522_H...+BXi+1206D.html - Hifi<<<<
http://www.sonicelectronix.com/item_3474_M...io+HK1000D.html[/url] - MA<<<<
Edited by BackYardSoundZ
