I don't know much about the vehicle but you can do a full rewire on the car and if you have to have to factory radio to make the car work, then you can make your own buss cable to mount it out of the way.
At the end of the day the price will still be close to the bypass unless you can get all of your new speaker wire and wire for your buss cable for dirt cheap.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
crutchfield will be 50 bucks more than other sites. off to ebay you go.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
X 10
well i found this throw google
http://mobile-emotions.com/car-install-parts-vw-volkswagen-2008-rabbit.html
seems cheaper then crutchfield
and it the crutch field harness says 2002-new so ima see if the 2007 harness looks the same as the 08 but i think it is
heres the thread i got this stuff from so if anyone wants to help me out id appreciate it alot
http://volkswagenownersclub.com/vw/showthread.php/11380-Head-unit-wiring-harness.-Question?p=159125&viewfull=1
NoFearX18 said:
trainman0978 said:
is that the right harnnes nick because if it is ima save that and once i have the car at home ima buy all this stuff so i atleast have a nice headunit
yes thats the right harness...its a metra piece. i think there the most reliable as it is. thats what we use at my job
NoFearX18 said:
trainman0978 said:
