xBIG-MIKEx Posted March 23, 2011 Report Posted March 23, 2011 I'm still fairly new to the whole car audio world, and need some help. As of right now i have a small "starter amp". Its a 600 watt 4 channel sony xplod. I have a pair of 12" JL W3's bridged off the amp and they work just fine. However, recently i went to connect another sub to the amp as well, and found out that the other set of terminals are putting out no power. no matter what i do, it just wont do anything. The amp as two channels for each side, front and rear. The rear channel works fine but the front does not. Please help me figure this out. Thx
iKidwell Posted March 23, 2011 Report Posted March 23, 2011 it's probably just because its a sony xplod..it's not worth fixing..save it for the 4th of july and strap like 6 big ass fireworks to it and see if they can get it off the air and blow it up c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old. i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer. 2003 Infiniti G35 Sport Sedan Build in Progress
xBIG-MIKEx Posted March 23, 2011 Author Report Posted March 23, 2011 im planning to replace it with a fosgate amp in the near future, but would like to be able to use it in the mean time
kickass audio Posted March 23, 2011 Report Posted March 23, 2011 Hey, did you try to swap rca's (put your front rca's on the rear and vice versa)? Also try to not bridge it just for testing and go channel by channel to see if it is working, this will tell you whether or not your channels for the front are working or if a rca is loose at the h/u. Also how do you have the amp bridged? From what i have seen should 99% of the time be the left channel Positive and right channel negative (in your case for both the front and rear output terminals) You CAN NOT try to bridge by taking the left channel positive of the front left speaker to the right channel negative of the rear right side, it will not do a damn thing. Also if you try to bridge in two ways for example you are just using your front outputs and you currently have it bridged using the left channel positive and right channel negative, you must NOT use the left channel negative and right channel positive. The left channel negative and right channel positive will be pretty much dead since it is not intended to be double bridged on the same outputs (if that made any sense) And finally, what impedance are your speakers? If you have different impedances it can affect the amp sometimes. 2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
xBIG-MIKEx Posted March 24, 2011 Author Report Posted March 24, 2011 The way i have it bridged currently is by using the rear channel, with (+)left and (-)right. It sounds fine when its set up this way The amp is set up with two sets of RCA input jacks (front channel and rear) and the rear channel terminals are (+)(-)(+)(-) and front (+)(-)(+)(-) Whenever i try and use the set of terminals for the front channel, its like my subs are not even plugged in. Ive tried both bridged, and using the individual channels and still get nothing. Im not 100% on the impedence, i believe its 4ohms. The way the guy set them up is that there are two subs (both have 4 ohm impedence individually) and the box only has 1 terminal, idk if that may change the impedence or not. However the impedence shouldnt be a problem, because i tried the same thing with my other sub (which is 4ohms) and still got nothing
t-money Posted March 24, 2011 Report Posted March 24, 2011 as said b4 did u swap the RCA wires from rear to front? 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
xBIG-MIKEx Posted March 24, 2011 Author Report Posted March 24, 2011 as in completely swap the cables? or have the RCA run from rear channel on head unit to front channel on amp and vice versa?
bass_stalker Posted March 24, 2011 Report Posted March 24, 2011 4 channel amps need 2 sets of rca's to run both sets of channels at the same time JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
xBIG-MIKEx Posted March 25, 2011 Author Report Posted March 25, 2011 I've got a pair for both channels. The amp just doesn't seem to put out a signal
