A wire sized hole? I'm pretty sure your supposed to use a ring terminal and bolt it onto a spot on the chassis thats been sanded clean like said before
I think he meant drill a whole through the body so you can get to the chassis. Then bolt it down to the chassis.
Yes. Frame of the car and chassis are the same thing, right?
Yes sir
Big 3 with Yellow Top
So if I do have a battery in the back and I had it grounded to the seat belts and then from the batt to the amp. Do I definatly have to run a wire dirrectly from the main batt to the trunk batt and then to amp? And do I also have to ground the back batt to the trunk of the car or will just from the front batt to back batt be ok?
Yes sir
Alright i thought i was missing something because i did say frame.
OP, just a neg run from the front batt to back batt is fine. Just make sure the front one is grounded well.
Edited by DannyV18
If you have a battery in the trunk, you should have the amp grounded to the negative terminal on that battery. And you should have 2 runs of 1/0 (1 power, 1ground) going from the front battery to the rear battery. Also make sure that there is a fuse at each battery positive. And yes I think it's a good idea to have a ground going from the rear battery to the chassis as well.
  • Who's Online   0 Members, 0 Anonymous, 695 Guests (See full list)
