Hey guys I have 2 sa12's and and running off of a sax 1200d and plan on jumping to the saz 2500d. I have a yellow top optima under the hood now and I have an xs power 3400 on it's way, I have heard it's not good to mix batteries but I really don't want my optima to go to waste, I just bought it like 2 weeks ago. If it's ok to mix both will go under the hood, which one should go to the amps...
4000 watts? The site says 2500 at 1 ohm. Even then your doubleing what those subs are rated for. It might be risky.
Big 3 with Yellow Top
ive mixed a yellow top with an XS power batt
not for long cause i was upgrading to all XS but i had no problem
both bstts stil hold a charge and the yellow top is now in my buddys truck
the batts will be fine
but if your gunna run XS i would eventually get another XS batt to match eventually
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
youll be fine running that much power to the sa 12's just be careful of clipping and feed em clean power
BHE Wall Build
TEAM DC Audio
TEAM XS POWER
1986 Monte Carlo
KMC Nova's 20"
4 DC XL's W/ PSI Recones
2 DC 5k's
Pioneer PRS 80
10 Audio Technix
6 XS Power D3100's
1 XS Power D3400
Mechman 220a Alternator
i think you will be fine, with the batterys i done it before , just dont do it for long also i doubt he is goin to see the full 2500 anyway with box and impedance rise and the voltage he is goin to drop he should be fine if you set your gains right (oscope it)
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
