okay, so previously i had my two CVX 12's in a box and setup my terminals like meade shows us in
(around 0:20). i had been using 16 gauge wire previously and i could bang full tilt for hours (as long as i was driving of course)
recently i decided to carpet my second box. in the process of taking out the box, i managed to forget to unscrew the terminals, and ultimately ended up ripping the wire from the terminal.
so i had some 12 gauge lying around, and decided to hook that up with the wire just running through the port and skipping the old terminals altogether.
now, when i turn the bass up past a certain level, the amp shuts off (i'm assuming it's going into protect mode). i checked the speaker connections, and they were all pretty solid. recently i've been able to turn it up a little more before it shuts off, but i start to smell burning copper when i do.
when i had it set up the old way, i could turn it up as loud as i wanted, the woofers wouldn't even get warm, i never smelled coil, and it was actually louder than it is currently.
the speaker wire is literally the ONLY thing i changed, and it's worked great before.
any ideas as to what could be my problem?
extra info:
amp is a zx2500.1 running at 4 ohms.
woofers are dual 4 ohms
Edited by 412 CVX
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
You have something pluged in wrong.
i checked all of my connections earlier today. everything was plugged in right
More box builds
Swap back to the 16 gauge and see if the problem goes away.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i sure as hell hope that's not the issue, because it doesn't make a bit of sense! :wacko:
How are you wireing your subs up?
read the first post again. :good:
it's hooked up exactly like this ^^^
More box builds
i called kicker and they said i might have a bad ground, but i don't see how that could be since i didn't touch the ground.
any thoughts?
More box builds
:bump:
check the ground and all your connections even if you already did
did you mess with the gain at all?
i had a kicker zx.850.4 do the same thing and i sent it off and im awaiting a new one
turn the gain all the way down and see if it still does it
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
:bump:
i did turn the gain on the amp down a little bit because it was at full tilt, even though i have the remote bass knob that came with the amp and i use that as well. but recently i turned the amp back to the original settings and it still does that.
i'll check my ground even though i doubt it's the problem.
could it just be a bad amp?
More box builds
