Does EVERYTHING clip?
wave height means nothing other than its a stronger signal/more power. When you get square corners and flat tops/bottoms then you're getting clipping.
Hammerdown... 1%
thats what I was asking skittles, thanks guys I was worried I was doing something wrong because like I said from the videos I have seen on web the tpi 440 screen video wave never goes as big as the large ones in my pics and the instructors just stop at the smaller wave like the small ones in my pics.
Why do they settle for the smaller wave over the larger one? :turkey:
What Radio do you have?
My Alpine CDA-117 doesn't clip at max volume unless you turn the bass all the way up or crank all your low frequencies on the EQ.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
not meaning to jack here. but will my clip light on my aq amp work the same way as an oscope? cuz thats how i been adjusting my bass amp with lol
kenwood KDC-MP424
most likely same as yours mine can go to 35 but wont square off but I leave buit in EQ at 0 for bass/mid/treble even so I lower volume to 28 wave still a bit tall just for safety. From their I go to Clarion EQS746. I have RCA from front RCA's going to EQ main input then RCA's from sub out on EQ to bass amp, then RCA'S from front output on EQ to mid/high amp.
When I leave HU atvolume 28 going to EQ I play tone for the amp I'm messing with and look for clipping on those RCA's and with both sub level knob all the way up and volume knob all the way up neither 50hz or 1khz tones square off, the 7 bands on that EQ are mid way through turn. This is why I wonder if it would be bad to turn all the bands all the way up BEFORE setting volume knobs on EQ. Then set gains on amps, once their I would just lower the bands that sound to rough on particular songs.
how much that oscilloscope cost ya?
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
Set it to ACV, by the way...
Thanks for that Boon!!!
When I am going off the actual RCA's as well as amp speaker terminals I don't get nothing on Oscope so I have to put it on ACV. The pics are off the male end of ipod jack that goes to head unit wave doesn't change just the mV does sorry about that.
To add to this my friend was over yesterday and helped him with his gains, He also showed me the same EQ I have and asked me to hook it up for him. I did it but the difference between his install and mine was that on his EQ I turned all the bands up and as well as the the sub level knob THEN I set volume knob and actually saw clipping so I backed that down till wave smoothed out. Everything else was set right also. All he needs now is an upgrade on his sub stage.
  • Who's Online   0 Members, 0 Anonymous, 1424 Guests (See full list)
