ii am getting a very bad alternator whine. It started after I put battery in the back and redid system wiring. Car was always quiet before. I've ran 2 extra grounds from battery to chassis with no help. Changed all rcas with no help. Amps r grounded directly to battery. Made 2 new grounds to headunit, didn't help. New 18g power wire to headunit. Ran hu power directly to distribution block. Motor has factory plus 2 grounds from alt to chassis and engine to chassis. Nothing has helped at all. Any other suggestions?
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
Audiocontrol Epic-160
Pioneer DVD head unit
alt can be going bad :shrug:
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
ii have noticed alt output is only 13.8 @ alt when last month it was 14.2
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
I have that same problem and people told me my alt was going bad also. Im putting too much stress on the little guy. Soon to be R.i.p. stock 70amp alt lol
No car at the moment.
New system:
2 Skar Audio VVX-12s
Crescendo bc2000d
Carquest NGT battery (back)
Deka battery (front)
Went to local alt rebuilder & he tested it. Says its fine, putting out 85 amps & diode good.
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
have you done Big 3 ?
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
could be the alternator bearing on the pulley
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
Yes. I posted I upgraded all grounds. Got a 2/0 from alt to distro block. A pair of 2/0 engine to frame grounds. Battery is in back, has a pair of 2/0 ground wires going to seperate locations in hatch area. I even ran new power and rca wires outside of car for testing and it didn't helpp at all. I've prolly installed 125+ systems in 15 years and I've never had a noise problem this bad that I can't fix.
99 GMC Suburban
2 Death Penalty 21"
2 Crescendo BC2000
Boston GT-42 Amp
6 Selenium 6w4p
4 Crescendo tweets
Hi output cs144 alt
Im not sure but have you cleaned your ground, like sanded off of paint?
Maybe rcas are to close to power and ground wires? Idk if that might help or not.
Posible headunit or amp? Im puzzled as much as you are
Edited by sr20daze
Hahah damn cody
She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch.
you dont find dubstep, dubstep finds you
hu: Pioneer MVH - P8300BT
mids: Alpine sps-600 all four corners
highs: Addictive Audio ECST25A,Memphis PR tweeters back
sub: 15 inch crossfire bmf
box: 4 cubes at 38 hz
amp: Rockford Fosgate Power 1000 25 To Life
140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q)
Build Log
http://www.stevemead...ima-56k-beware/
Feedback
http://www.stevemead...s-bfd-feedback/
