using diodes to step up voltage
Sheeeiiittttt! No problems? Smoothe sailing?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Anyone still doing this? trying to figure out the sensing wire for my 99 jeep cherokee 4.0
My friend had a 1996 Cherokee with the 4.0 and it was externally regulated from the factory. Had a field terminal and everything. If that's the case with yours you could just get one of the blue transpo regulators and wire it up
http://www.motorcityreman.com/13advore.html
Yes those do work for my setup but I am still going to attempt the diodes tonight. Only have two wires on the plug for my jeep so It shouldn't take long and if neither work I'll solder them back together.
  • 2 years later...
I know this thread is old but i found something that might be useful
i have gotten the diodes to work on mopar alts, i have a 05 pacifica and the alt only has the 2 field wires
In my case i tapped into the wire from the fuse box to the pcm (in my case fuse39 org/red wire) that is unswitched with ignition
the pcm reads and adjusts your voltage based on this wire
it's a 20a fuse so i used a 30a Schottky diode
my voltage went from 13.6 to 13.9 hot (still 13.6 at pcm)
I'm going to order some more diodes from mouser to do a bit more testing
