Box Tuning Calculator question.
I made a post sometime in the past where someone on here gave me a link to download a program called Box Tuning Calculator and it is amazing. However, I do have a question which might prove how ignorant I am in car audio/math. I plan on making a T line box for two 12's, dimensions around 17" tall, 37" wide, and around 23" deep. I originally entered the port height at 15.5" (compensating for the .75 inch thickness of top and bottom of box, idk if you're supposed to calculate that in), width 5" and the depth around 19", all rough measurements so far. The thing I am confused on is the wider I make the port, the higher the frequency tuning goes, and the smaller the port width is, the lower it goes. I thought more port area means lower tuning? Plz educate me!
No, more port LENGTH lowers tuning.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
So port length lowers tuning, width heightens tuning. So if I am stuck with around 19" of port length, I simply decrease port width lower the tuning to my prefered 31-32hz tuning?
Not necessarily. A port that's too small may cause peakiness and port noise.
LMFAO so true
:blush:
If you can only go 19" deep with the port, you can bend it and get the desired length for the tuning you want. The port will look like a L
a couple things to clarify:
when adjusting port length with a fixed surface area, increasing the port length lowers tuning and shortening the port raises tuning.
when adjusting port area with a fixed port length, more port area raises tuning while less port area lowers tuning
my calculator (i'm assuming it's the one you're using, given the similar title in the first post) is made to design ported boxes. if you're trying to do a t-line, my calculator will not be able to help you. t-lines are basically considered one long port, while ported boxes have airspace. the math for a t-line however is very simple to understand
  • Who's Online   0 Members, 0 Anonymous, 793 Guests (See full list)
