the dp 21 is dual 4 ohm if i recall so itll be wired down to 2 ohms. most of the amps i looked at were only about 2000 watts at one ohm
do you already have the sub?
you could do two AQ2200Ds strapped at two ohm, that would be $780 for both amps
i didnt order it yet. i'm gonna try to do the big three and batteries plus run all my wire before i buy the subs or the amps
does the sub come in Dual 2? if it does get the dual 2 ohm version
i think it might. it looked like it said dual 1 ohm or dual 2 ohm tho. so im guessing it was talking about dual 4 or dual 2
Well how much power can it take rms??? 3000??? also get the Dual 2 and run it at 1 ohm to save $$$ on a big amp you wont need.
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
the sub takes 3k max and 1500 rms. unless ive been reading the amp specs wrong none of them can give me the 3k max at two ohms
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
Ahh well i just looked up that sub 21" thats crazy. well it says its rated at 1500 Rms. Soooo i would get one AQ2200 and one of those in a dual 2 verson and run it at 1 ohm
2000+ watts rms to a 1500 rms sub will make it slap.
Plus with that amp you would only need 2 battries, a HO Alt and a bunch of 0 Gauge.
so those ratings on the aq were at rms power? i thought those were max ratings
Dont worry about max power :shrug: Max power is silly an AQ2200 will Slap that sub.
No those are rms. 2000 rms would be great.
they are RMS but since the sub is 1500 RMS like powerhouse407 said a single AQ2200D would be a good match and you dont need crazy electrical to run it
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
well i i think i got the electrical figured out 280 amp dc alt and 2 d3100's or a d3400 and a d3100
....read the site? That is it's rms.
1500 watts RMS/3000 peak
  • Who's Online   0 Members, 0 Anonymous, 609 Guests (See full list)
