Go-N-Def Posted April 11, 2011 Report Posted April 11, 2011 I have a Crossfire vr 1000 and thinking of getting 1 more. They can put out 1300 each which should give me 2600 watts., But the 2000 puts close to 2400 watts. I want to know if the 200 watt difference matters. Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
blownengine Posted April 11, 2011 Report Posted April 11, 2011 More power is more power. 1 amp is more efficent than 2 however. 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
jmilch Posted April 11, 2011 Report Posted April 11, 2011 More power is more power. 1 amp is more efficent than 2 however. And for this reason 1 larger amp is generally better than 2 smaller amps, if you factor in efficiency and the cost of wiring up two amps. Pioneer AVH-P4300DVD | Hertz 6.5 | Alpine Type R 6x9 | Custom 200A Alt | Knu Flek 1/0 Big 3 and all wiring | Eclipse EA3422 | AudioQue 2200d | DC XL 12 | Red Oak Box ~2.8 cubes @ 30 hz |
blownengine Posted April 11, 2011 Report Posted April 11, 2011 More power is more power. 1 amp is more efficent than 2 however. And for this reason 1 larger amp is generally better than 2 smaller amps, if you factor in efficiency and the cost of wiring up two amps. And one big amp is almost always cheaper to buy than 2 smaller ones. 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
Autruche Posted April 11, 2011 Report Posted April 11, 2011 Keep in mind that you cannot attain the same nominal impedence load with one amp vs two amps. That is usually the deciding factor. If you have 2 D2 subs, then you can have 2 amps at 1 ohm loads each (strapped at 2 ohms) or one amp at .5 or 2 ohms. Or with D1 coils, it's vice versa. Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want
hdorre Posted April 12, 2011 Report Posted April 12, 2011 More power is more power. 1 amp is more efficent than 2 however. This. 1 amp generally has less impedance rise than 2 strapped amps too On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Go-N-Def Posted April 12, 2011 Author Report Posted April 12, 2011 More power is more power. 1 amp is more efficent than 2 however. And for this reason 1 larger amp is generally better than 2 smaller amps, if you factor in efficiency and the cost of wiring up two amps. And one big amp is almost always cheaper to buy than 2 smaller ones. Got 1 Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
