TheyDontWantMusic Posted April 15, 2011 Report Posted April 15, 2011 No it is extremely obvious you think it is a transmission line when your port area isn't even right? How does that work? Please I am all ears Dr Tline. I've given you the dimensions, go model it as a ported box. I look forward to hearing your ignorance yet again
korey_hofer Posted April 15, 2011 Report Posted April 15, 2011 it's pretty obvious you are clueless because what you are claiming it to be is a quarter wave length guide NOT a transmission line. A transmission line disrupts the rear wave and absorbs it so it can't interfere with the front wave while not adding any back pressure. what you have is a very high tuned ported box because it is adding pressure whether negative or positive and your subs are all seeing a different ''line'' length previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
AMI CUSTOMS Posted April 15, 2011 Report Posted April 15, 2011 Oh perfect!!! Just for you. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
TheyDontWantMusic Posted April 15, 2011 Report Posted April 15, 2011 it's pretty obvious you are clueless because what you are claiming it to be is a quarter wave length guide NOT a transmission line. A transmission line disrupts the rear wave and absorbs it so it can't interfere with the front wave while not adding any back pressure. what you have is a very high tuned ported box because it is adding pressure whether negative or positive and your subs are all seeing a different ''line'' length wow, you really are confused. please, go model it as a ported box and let me know what you find. should be amusing.
korey_hofer Posted April 15, 2011 Report Posted April 15, 2011 it's pretty obvious you are clueless because what you are claiming it to be is a quarter wave length guide NOT a transmission line. A transmission line disrupts the rear wave and absorbs it so it can't interfere with the front wave while not adding any back pressure. what you have is a very high tuned ported box because it is adding pressure whether negative or positive and your subs are all seeing a different ''line'' length wow, you really are confused. please, go model it as a ported box and let me know what you find. should be amusing. I am not confused at all. obviously you are. you honesty believe that using 1/4 or less of the line area you should be and having subs loading 1/2 way down the line is going to act like a "tline" previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
TheyDontWantMusic Posted April 15, 2011 Report Posted April 15, 2011 I am not confused at all. obviously you are. you honesty believe that using 1/4 or less of the line area you should be and having subs loading 1/2 way down the line is going to act like a "tline" of course. the woofer doesn't even have to be at the start of the transmission line. this is basic transmission line design theory. go and play with hornresp, its pretty accurate in its plotted response. http://sites.google.com/site/radioandelectronics/tapered-quarter-wave-tube---voight
DannyV18 Posted April 15, 2011 Report Posted April 15, 2011 A true t-line for 16 10's would be gigantic.
korey_hofer Posted April 15, 2011 Report Posted April 15, 2011 I am not confused at all. obviously you are. you honesty believe that using 1/4 or less of the line area you should be and having subs loading 1/2 way down the line is going to act like a "tline" of course. the woofer doesn't even have to be at the start of the transmission line. this is basic transmission line design theory. go and play with hornresp, its pretty accurate in its plotted response. http://sites.google.com/site/radioandelectronics/tapered-quarter-wave-tube---voight your a joke dude, I'm not even going to explain why your wrong. you decide you want to know why send me some cash and then you can learn a little bit previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
TheyDontWantMusic Posted April 15, 2011 Report Posted April 15, 2011 A true t-line for 16 10's would be gigantic. yes, but you can compromise efficiency for size. plus the box was designed to act as a tapped horn with the car forming the rest of the enclosure, which I plan to experiment with extending the box over the woofers.
AMI CUSTOMS Posted April 15, 2011 Report Posted April 15, 2011 I am not confused at all. obviously you are. you honesty believe that using 1/4 or less of the line area you should be and having subs loading 1/2 way down the line is going to act like a "tline" of course. the woofer doesn't even have to be at the start of the transmission line. this is basic transmission line design theory. go and play with hornresp, its pretty accurate in its plotted response. http://sites.google.com/site/radioandelectronics/tapered-quarter-wave-tube---voight your a joke dude, I'm not even going to explain why your wrong. you decide you want to know why send me some cash and then you can learn a little bit Bingo!!! TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
