Check your nominal load the amp is seeing, most likely it's too low.
If that's not it, open that bish up and look at the mosfets and take pics, they are probably toasted.
If it was at too low of an impedance and switching it to a higher impedance doesn't work, than you might have burned up the mosfets from running it at too low of a load. I know that from experience.
Need Test Tones/Sine Waves? Click Here!
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Pioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE Audio
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
Hit me up on Facebook, if you want
if its a dual 4 ohm sub that would be wired to 1 ohm at the amp check to see is your amp can do 1 ohm
if there dual 2 ohm subs that is 0.5 ohms at the amp wich that amp should not be able to handle
They are single coil selectable
so there single voice coil with a switch that lets it be 4 ohm or 2 ohm ive never heard of this
Yea how does that even work? Check it with a DMM
Big 3 with Yellow Top
Quite simple in theory, a dvc sub with one 4 ohm coil and one 2 ohm coil, but you have a switch that only lets you use one coil at a time.
My Saab 9000 build
Seems kinda inefficient. With the sub carrying that extra weight around. But useful for the everyday guy.
  • Who's Online   1 Member, 0 Anonymous, 354 Guests (See full list)
