Component advantage over coaxials
I'll be doing two sets of 6.5's for my doors. Each door will have the 2 drivers and 2 tweeters all mounted right next to eachother. Since the tweeters are right next to the mids anyway, can't I get the about the same sound from the coax's? My plan was for two sets of thesecomponents, but now i'm thinking about these6'5 Coax. Thinking about the change basically for getting the power I need from my amp and ease of wiring.
SMD Super Seller
My Feedback Thread
hope your not paying retail for those :P should be close, if it were me I would get components and find a way to mount the tweeters higher, will sound much better
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
The issue I have is the crossovers make for some crazy final ohm numbers, so wiring is a bitch.
I've always wondered that... What would that come out to for the 6.5 components?
It can vary from set to set. That means you won't know until you buy them. My Infinity sets came out to ~5 ohms wired in series. So it probably would be ~1.25 parallel. The RF's I want, no idea. Fortunately, I know someone that can test it for me if need be.
Edited by OrionStang
SMD Super Seller
My Feedback Thread
It really depends but usually coaxials are really really cheaply made unless its a more expensive prosound unit which then are too deep for auto use alot of the time.
I'm actually looking at the pictures as we speak. I think you're right, the components seem to be of better quality.
EDIT: Side by side they are no that different. Hard to tell without holding both in my hands.
SMD Super Seller
My Feedback Thread
I run these for rear fill so they aren't at full volume ever but when I was putting them in and cranked them up I was amazed how much midbass and how clear they were.
http://www.woofersetc.com/p-9609-hcx-165-hertz-65-2-way-hi-energy-coaxial-speakers.aspx
I haven't ran Rockford mids and highs but comparing the Hertz comps to coax the coax definately could get the job done nicely.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
