Drilled a hole in my gas tank..
ha a self tapper is what made the fucking hole!! and no im not dumb enough to weld around it. i was afraid to even light my torch to solder some 0awg in my garage tonight lol
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
Hole is fixed time to put tank back on and continue this build!
Good shit bro :good:
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
i found that jb weld doesnt like gas and heat for that matter i tried to replace part of cracked carb in the moped and it set worked for a little then ate through the jb weld within couple days
The gas tank sees no heat whatsoever though, and personally id leave it just how you have it. If you ever smell fumes, go to the junk yard and buy a new one. until then FUCK IT
Bang em if you got em
That's exactly what I have said.. FUCK IT lol
Im not gonna read all the replys..
Simple fix man.
Autozone...or pepboys
They sell gas tank repair kit. It will hold. Its made for this exact problem.
Thats all u need to do.
Period
Yup its now fixed ray, I made up my own patch kit ;) but glad I did cuz its now back to building instead of fixing said gas tank! So if you want you could lock this bad boy /thread
something i learned in welding school is to drain all the fuel and fill the tank with water all the way up to the spot to be welded. this will keep the combustion chamber so small that even if it did explode it wouldnt actually do any damage to anything.
a good weld to plug up the whole with no leaks is going to make the tank good as new.
good luck no matter what your solution :D
no pics sorry. it was on the top and only dropped the tank low enough to patch the hole
