if it were wired backwards you would be melting the fuse not just popping it
R.I.P!
(Nov-29-2009)
92 explorer
current build
eh?
most amplifiers with internal fusing have a diode across the input, so if you connect the battery reverse polarity, the diode conducts, and blows the fuse.
eh?
i donno the past 2 shitty amps i had done that to the fuses just hit the power and started to melt the metal
R.I.P!
(Nov-29-2009)
92 explorer
current build
try hooking it up the other way. if the label isnt wrong then the amp is fuck anyways.
so if i accidently hooked up the battery wrong i most likely fucked the amp?? because i was an idiot an didnt look at the labels on the battery :noob:. man this sucks more hassle
well i guess ill just send it back saying it was broken when i got it :D
but i guess ill try hooking it up backwards on the amp??
I would simply assume the amplifier is dead.
I agree.
crispy fried amp
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
try it hooked up correctly first. see if the fuse saved it.
yeah the first time i hook it up it was hooked up correctly on the amp but incorrectly on the battery. im still mad at myself for making an error like that
