07 Tacoma walled off with 4 15's
you can always add a couple of thread rods and brace the box better without taking away a lot of internal space, just saying :drinks:
The only thing I don't like about using all-thread for bracing is how it will stick out of the box. But idk, I might figure out a way to do something with that and still be able to cover up the bolts.
Use pieces of wood for internal bracing. It works, and it's cheap !
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
it also takes up more space and adds weight to the wall
assuming your school has a welding program just make up some threaded rod and a mounting plate
just weld a nut to a piece of flat square and then drill 4 holes like the pic and mount from inside the box
R.I.P!
(Nov-29-2009)
92 explorer
current build
Great idea, thanks for posting that. I can mig weld so that is defiantly an option. More strength+less loss of vb+still looking clean=major win!
then your laughing if you have access to a mig
best way to do it would be get your rod cut it to the inner dimensions of wall
get your flat bar drill 4 holes for corners weld a nut in the middle
thread the rod into both plates then slap into the wall and mount from inside using screws
being able to weld/having access to welder has made working on car/audio sooo much easier :yahoo:
and build looks good keep it up and one day hopefully you have better gear haha :santa:
R.I.P!
(Nov-29-2009)
92 explorer
current build
Cool thanks. I'm back from school now so I actually don't have access to my own mig anywhere too close.
I'm going to do the body work on the port and paint it, put blue leds inside the box, fiberglass all the inside corners and take out the old bracing and make some metal ones like this one day soon I hope.
After I get those goals done I will buy better gear lol
Very nice Build !! :drinks:
Kenwood KDC-BT33
Sundown Audio SAE-100.4  -  4 Crescendo Audio SC-650s
Sundown Audio SCV-6000D  @  (.5 ohm) ‎  -   2 DC Audio LVL5 M5 Elite 15s (d2)
6.45 ft Box ( Net ) tuned to 30 Hz  -   (  APM - 2  = 151.2 db  )
2004 Chevrolet Trailblazer LS 4WD
Brand X 390 Alternator - XS Power PSC30
XS Power D3400  (front)  -  3 XS Power D3100s  (rear)
Knukoncepts Kolossus Flex 1/0  -  SMD Meters  -  SMD Fuse Holders
Sky High Copper Battery Terminals  -  Amp Lab RPMC v2
SPL Cartel Bass Knob  -  Toolmaker Copper Amp Inputs
WOW! I stared at these pics for a while... This is IMPRESSIVE! BOSS or not... What a build!!! :clapping:
I wanna see a vid :popcorn:
2001 Chevy Silverado Ext. cab - Kenwood KIV-BT901 - 2x 12" DC Audio level 3 m2D1 in 4.2 cuft. @29Hz. - DC Audio 2.0k - Alpine Type-X components - US Amps USA-4300x - XS Power D4700 - Bosch 145a alternator
Also, how'd you get access to all those damn saws and shit??? Is this in a shop class or something?
