nope... i dont think so... prob be best to call an verify, but im sure that dont even sell welding wire
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
can i find Ogauge wire at Lowes and what type is it called?
- noob
Idk, but you can get it here. One of the mods (I think KingSUV) swears (or swore) by that online store
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Lowes or HD won't have welding cable. (that's what you need, not mains cable) You can find a local welding supply store or that link hdorre put up.
The big 3 is about the most important electrical upgrade you can do. It alleviates the need for capacitors (capacitors are a band-aid, a dirty, moldy, bacteria ridden band-aid) by allowing your electrical system to supply as much current as it can to your amps. Stock wiring is fine for starting your car and running your headlights, but was never meant to supply peak demand to an audio system.
This should be done before adding batts and alts... and in a lot of cases alleviates the need for upgrading those too.
Edited by srp365
2007 Pacifica
Thank you, but is there a diff between 1/0 and 0 gauge?
Another noob guestion, whats the diff if any from 1/0 and 0 qauge???
1/0 (one ought) is simply 0 gauge
2/0 is 00 gauge
4/0 is 0000 gauge
2007 Pacifica
