honda97 Posted April 20, 2011 Report Posted April 20, 2011 Whats Up i have 4 12 inch kicker comps wired for a 1ohm load to a hifonics 1000d.. i will be gettin another amp for my mids and highs. wat i need to know is if i need another alternator or will adding a kinetik hc600 be enough to stop my lights from dimming when the deep low beats hit? i have a stock 90 amp alternator. please help me and how would i wire the battery?
XX7R Posted April 20, 2011 Report Posted April 20, 2011 If I were you I would prolly get a bigger alternator & not have a dual alt setup lol.. And if you wanna do a battery in the back you just have to do a run of wire from front +battery terminal to back +battery terminal but put a fuse as close as you can on the wire on both front and back. A negative run from front to back will also help with voltage but isn't necessary 1990 Nissan 300zx Twin Turbo - Summer Ride(No system yet, lookin to get it up to 450-500 horse first!)2006 Chevy Malibu - Daily DriverDC Level 5 15", 2 APSM-1500's, 3.88 cu. ft. tuned to 32hz1992 Honda Prelude - SOLD2 18" TC 3hp Woofers on a Crescendo BC3500.1d, 12.7 cu. ft. tuned to 35hz
MrSkippyJ Posted April 20, 2011 Report Posted April 20, 2011 have you done the big 3? if not do that first, then try a second battery. If you still have voltage problems start looking into a H/O alt. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
blownengine Posted April 20, 2011 Report Posted April 20, 2011 Alternator before batteries. You shouldn't get crazy voltage drops on that amp. Do you have the big three? Or maybe a better battery. 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
94retta(219) Posted April 20, 2011 Report Posted April 20, 2011 Do the big three, run some zero gauge to a dist. block in the back and upgrade your batt up front. That should be enough for what you have. Still have problems after that then your alt could be old an wore out so then yes replace it. BUILD LOG
Guest Posted April 20, 2011 Report Posted April 20, 2011 If I were you I would prolly get a bigger alternator & not have a dual alt setup lol.. And if you wanna do a battery in the back you just have to do a run of wire from front +battery terminal to back +battery terminal but put a fuse as close as you can on the wire on both front and back. A negative run from front to back will also help with voltage but isn't necessary wait...a bigger alternator? for a 1000w amp? he will be absolutely perfectly fine with just the big 3. edit: the hc600 will help, just run 0 gauge from the front battery to the hc600 in the back and wire the amps off of that.
fecupe2001 Posted April 20, 2011 Report Posted April 20, 2011 I wouldn´t waste my money on a HO alternator with barely 1000 watts, just saying!!! big3 and an extra battery should help you out... I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
