Ok.. I got my RFX9420 today so I called Rockford Tech today to get some information. I asked the tech if the Rockford RFX9420 deck would cause any harm to my amps since the Rockford RFX9420 has 8 volt pre outs and the Amps only have 4 volt inputs.
The Tech told me that it will be fine that all I had to do was adjust the gain on the amp and that it would probably be almost all the way down. I asked him again "Will 8 volts pre outs burn out the rca inputs if they are only rated for 4 volts " and he said no that they do it all the time.
What are your thoughts ?
is this just a gain setting only on the amp ?
I just want to make sure everything is square before I do anything.
Which amps?
Some amps don't like more then 5 volts or they will go into what's called "DC Protect"
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Which amps?
Rockford Fosgate T40001bd
Rockford Fosgate 500x
I asked the tech about these amps and he said it would be fine.. that it was just a gain setting on the amp even though the amps are only rated at 4 volts in.
Arn't those 8 volt ratings MAX ratings?
yes those are max settings
i'd assume you would just turn the gain all the way down and then turn the volume up till the preouts reach 4v.
Okay, if Rockford tech told you to do it, then you are probably fine and just do what he said to do. If anything burns up, it will be his fault. That is just my opinion...
BassinBlazer
JL[RF][Kenwood][AQ]
I need a new amp! Sell me your amp!
Dustin, you still at work bro??
Yes got 2.5 more hours
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
DC Audio Dealer
XS Power Dealer
