Alright well my dad got a nice camper but the only thing wrong with it is that the brake lights stay on ALL the time and everytime we do something or it sits there you have to undo the negative on the bat...
How would you fix this?
I want the brake lights to work normally.
Anyone know about this?
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
What kind of camper is it? A pull behind? and it only happens when connected to the truck right? Or is it like a motor home. Details details.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
more details would be great... but it sounds like the break lights are directly grounded to the frame of the camper so when the negative of the battery is connected it completes the circuit and turns the break lights on. use goolge and pull up the lights wiring diagram trace everything down. somebody did something stupid with the lights.
Edited by jsawdy212
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
check the wiring in the rear light housing.. sometimes it can be due to bad grounding that keeps the lights on
x2
It sounds like you have a bad ground or someone didn't wire something correctly. Check the Pin connections for the camper brakes and brake lights and verify all the grounds are good. Sounds to me like someone wired them up constant instead of to the rear tail lights like they should be, could also be the issue.
BassinBlazer
JL[RF][Kenwood][AQ]
I need a new amp! Sell me your amp!
