Getting a Rockford t400-4. Also I am getting the rockford t1652 components and the t1 6x9s. I want to give the 6x9s each their own channel. Then a set of components each into the other channels. How can i wire 1 set to equal a 2 ohm load into 1 channel for the amp?
Pioneer 6300ub
Rockford Prime 6.5's
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
1.4 Cubic Foot Enclosure Tuned to 34 hz
Stinger 4 Gauge Wires
you are running 4 speakers (I am counting each component set as a speaker) from a 4 channel amp with each speaker being 4 ohms. You want to know if you can each speaker up to be a 2 ohm load? If that is your question, then you can't.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
If your getting 1 set of componets and 1 set of 6x9s that's 4 speakers
4 channel amp=1 speaker per channel
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Just realized i sounded like a jackass in my post and made no sense. There will be 2 6x9s and a pair of components. But i want to put a woofer and tweeter into one channel as a 2 ohm load. is it possible?
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
a woofer and a tweeter is a component set, they will always be on one channel unless you go with a active crossover and use a seperate amp to separate them. Now to wire up 2 6x9s is possible for a 2 ohm load.. just wire them pos to pos to the amp then neg to neg then to the amp and you'll simply have a 2 ohm load.
Well i can wire the T1652 comps into a 2 ohm load and how?
Pioneer 6300ub
Pioneer 6x9's
Alpine MRP-M500
10" Alpine Type R
You can't just put 4 speakers on the first 2 channels and run them 2 ohm? I'd done this before didnt know it was bad?
Grand Cherokee
Team Backwoods Bumpers
DC 15" Level 3's /w 4 Coils
Pioneer deh4200ub
Pioneer 3-ways
Pioneer Tweeters
Pioneer GM-D9500F
Audiopipe 1500.1D @ 14.4v
Clarion Equalizer
Knuconeptz Kollosus 0ga
Knuconpetz Kollosus 4ga
Coming Soon: 270xp / xs1200
Why are you bent on running the amp at 2 ohms? You would to build a new crossover to make the component set a 2 ohm load and even then I'm not sure it will work.
F150:
Stock :(
Processor: DSR1
