Swirched HU's.. now engine noise
I switched from an Alpine 9887 to a Pioneer x920bt.
My first thought was to ground the RCA's to the HU chassis, but the RCA connections are not directly on this HU, they are extended about 6 inches off.
None of the wiring changed, just the HU.
Could it be because the 9887 had 4v preouts and the 920bt has 2v preouts?
And if you think thats the reason, can you reccomend me a decent/cheapish line-driver?
Thanks
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
I believe that the 920BT has 4v as well. I used to have one. More then likely the pico fuse inside the HU blew. Pioneers of that run had a major issue with that. I was lucky with mine. I didn't have that problem. If at that point you have whine, a line driver will only worsen the case.
www.phoenixphorum.com
Setup
HU: Eclipse AVN6620
Amp: Audison LRx5.1k
Mids: 6 1/2" Silver Flute's
Tweets: Clarion SSS601
No rears
Subs: (2) TREO SSi12.22's
Processing: Audio Control DQS, Phoenix Gold BassCube
Clarion Collector
HEAD UNITS:
7770 w/920EQ w/2nd 920EQ display
ADCS-1 w/CDC605
5780CD
DRX9375r w/DPH9300
DRX9575Rz w/DPH7500z* (*1 of2)
DRX9675z (2X)
AutoPC 310
HX-D10 w/DPH910
DXZ615 w/DPH7500z* (*2 of 2)
CDC655
DRX8275 w/DPH9100
DRX7475
5632CD
AMPS:
A007-w
1800A
A1200
A500
APA4200
APA4320
APX400.4M
SPEAKERS:
SSS601 (2X)
SRC4650
SRC5752
SEC571
SEW5107
BTW, shouldn't this also be in the HU section and not the speaker section. It was after all, the HU you changed, not the speakers.
Setup
HU: Eclipse AVN6620
No rears
Clarion Collector
HEAD UNITS:
ADCS-1 w/CDC605
5780CD
DRX9375r w/DPH9300
DRX9675z (2X)
AutoPC 310
HX-D10 w/DPH910
CDC655
DRX8275 w/DPH9100
DRX7475
5632CD
AMPS:
A007-w
1800A
A1200
A500
APA4200
APA4320
APX400.4M
SPEAKERS:
SSS601 (2X)
SRC4650
SRC5752
SEC571
SEW5107
I agree... I have a 920 BT almost new in the box sitting at my shop because it kept popping the internal fuse and doing what he said... Pioneer fixes it each time because it is under warranty, but after the 4th time doing that, I replaced it with a different model and no problems since...
all of pioneers h/u's produce ground noise from the RCA's i think, mine does, hence i need a new one lol
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
x2
Car: 1995 Thunderbird
System:
Pioneer deh5100ub HU
Pioneer/Lightning Audio 5x7's
1 Hifonics 1610D amp
2 Obsidian Audio 12's
4cu.ft. box tuned to 30hz
8 farad Boss Audio cap
4 gauge power/ground wire
Youtube
Facebook
I do apologize for it being in the wrong section, I will try to open it up and check out the small fuse. Mods can move it if they would like.
I think I clicked the wrong section when I posted it.
Also just checked the pioneer website, x920bt had three 2v preoutd, they are not 4v
Edited by JZeFF
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
3x XS power D2700's
You can still ground the rca's; it will reduce the bad noise a lot. But it may not be enough for you !
I had this pico fuse problem on my prs 88, and did not find replacement fuse; no more warranty. I found someone who just replace the blown pico fuse with a piece of wire with a small resistance (or something like that, I am not an electronic guy !!!). No more noise at all, and my h u was like new. I have it for 3 years now.
You don't need any line driver. Just set the gain right on your amps.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a 2.6 ft3  ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
I've only seen like 3 pioneers that don't produce ground noise, there's a pico fuse in the head unit that gets blown from swapping rca's 'hot'. Quick fix that I do that works everytime, strip a 6-8" piece of speaker wire put it on one of the screws on the back of the head unit then wrap it around rca's making sure it touches the outside of each one the take the excess and bolt it down on the back of the head unit. :good:
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
  • Who's Online   0 Members, 0 Anonymous, 1506 Guests (See full list)
