rev ur car up to about 1500 rpm's which is about driving rpm's and see if they dim. it should be putting out more than that at idle though.
2007 caliber
2 Fi ssd 18's
rd audio 3250
xs power d3100 (need 2 more)
stock alt (soon to be singer 350a)
2.75:1 4th order in progress!
And I said the resting voltage of your battery.
Okay, so I just went and blasted it for a good 3-4 min. The only lights that are dimming are my interior lights and my parking lights. My headlights don't dim at all, that I can tell. So...just extra batteries??
Float mounted IPad Mini playing through Bluetooth
IStreamer for Iphone or Ipad
Rockford Fosgate 3Sixty.3
RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors
Two Rockford T600-4's for the components
Blowthrough with two Sundown SA-8's
RF T1500-bd's for the subs
8000k H.I.D.'s in headlights and fogs
Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift)
17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's
Undercover Bedcover
Surco Roof Rack
Five Hella Lights on front bumper
270A Mechman Alternator
Two Optima Yellow Top batteries
Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
Yeah, I just don't have the tools. <_< But I've heard, AutoZone doesn't check alternators correctly unless it's actually out of the truck?!
Undercover Bedcover
Surco Roof Rack
Sorry, he didn't tell me. He actually didn't seem like he knew too much! He just kept wanting to know what kind of amp I was running that would need that big of alternator!
Undercover Bedcover
Surco Roof Rack
They can only test it incorrectly if they're truly inept. And I've run much more on similar electrical with 0 issues. They obviously don't like checking the batteries correctly either
even so, it may be a ground issue, you should have next to 0 voltage drop with that alt
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
Have you tested your voltage? Do you have a voltage meter?
so, i'm thinking i just need a battery?
Undercover Bedcover
Surco Roof Rack
You should find out what your voltage is to see if its dropping on a load. But I don't know, check grounds might be a good idea as well
