I have a grounding issue becausey lights are still dimming and I've always suspected my amp ground was the culprit. The local guys told me the seat bolt or seatbelt bolt, so that's what I did but I've never felt comfortable with it. Anyway, I'm gonna redo it tomorrow. Should I ground it to the frame or just make a new hole in the body, sand it down, and use a bigger bolt?
Float mounted IPad Mini playing through Bluetooth
IStreamer for Iphone or Ipad
Rockford Fosgate 3Sixty.3
RE Audio XXX 6.5's in each door with a second set soon to be added to the front doors
Two Rockford T600-4's for the components
Blowthrough with two Sundown SA-8's
RF T1500-bd's for the subs
8000k H.I.D.'s in headlights and fogs
Lifted 2" in front and 2" in back (soon to be installed a Suspension Maxx 1.5" body lift)
17" Ultra Rogue 175's on Nitto Trail Grappler 285/17 70's
Undercover Bedcover
Surco Roof Rack
Five Hella Lights on front bumper
270A Mechman Alternator
Two Optima Yellow Top batteries
Dynamat double layered each door and roof, quadruple layered on back wall, single layered on floor with Second Skin Luxury Liner Pro on top.
Already done big 3 and just installed a Mechman 270A and optima yellowtop
Undercover Bedcover
Surco Roof Rack
Battery negative is best. But sand and frame is the second best. Also do big three if you haven't.
x2
a lot of people sand and ground it to the chasis (including myself)
edit:if having dimming problems after changing the ground location, do the big 3 as Robert said, and/or get a bigger battery.
Edited by carlosg_313
How do the Japanese feel about bass?
You know that since 03/11/11
Progene? I just saw that stuff on CNN. They said it makes your junk shrink all up. lol.
im pretty sure the op wont even notice if it gets even smaller.
Refs - Pstone11, porksoda, coleman
So I was thinking of drilling a hole through the body, adding a grommet and running 0g ground wire to the frame and connecting there. Better, right?
Undercover Bedcover
Surco Roof Rack
Frame is better than the body if your vehicle has a frame...my unibody doesn't sadly :(
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
Yeah the frame would be better then seat belt bolt. But the battery negative is best. And look at your other thread I responded.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
So run a ground wire from the battery under the hood to the amp in the back? I always thought you were supposed to have the shortest ground wire possible?
Undercover Bedcover
Surco Roof Rack
So if I go out and buy another battery tomorrow, I could just use the battery's negative post instead...correct? Cause on a multiple battery setup, you just run power and ground wire from your battery under the hood to the extra battery, right?
Undercover Bedcover
Surco Roof Rack
Oh okay, I see! So, just ground to the actual frame and if I still get a little dimming, get another battery?
Undercover Bedcover
Surco Roof Rack
