I Have a Gold Duralast 1000 amp Bat Under the hood and was planning on getting a Kinetic HC1800 For the back.
Ill have (1) AQ2200D and (1) RF 300-4
how would i wire the 1/0 for my aq and the 4 gauge for the rf?
does anyone have a diagram?
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
Just read the title only.
And wire it in parallel.
u make no sense...
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
Im drawing a diagram now. Ill post it up in like 3 mins
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
just run 1 positive and 1 negative cable to the back. then connect them to the battery in the back. make sure you fuse the positive run at each end near the battery. once the battery is connected just wire the amps up the way you normally would off the battery.
The thicker wire is the 1/0, and the skinnier wire is the 4AWG. You basically connect all the positives together, and then all the negatives together
LMFAO so true
:blush:
thanks so much!
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
You're welcome :D
LMFAO so true
:blush:
  • Who's Online   1 Member, 0 Anonymous, 755 Guests (See full list)
