hi. i have 2 pioneer dual 4 ohm subs and i recently parallel wired them. since the subs themselves are wired parallel in my boz and then i have the 2 subs wired together through the terminals then one set of wires going to the amp does that mean i'm at 1 ohm or 2 ohms? i've heard both and i figured someone on here might know better. Thanks in advance!
http://www.sonicelectronix.com/item_16493_Pioneer-TS-W308D4.html
(i have 2 of these)
Edited by zach2323
As long as you keep a clean signal and set your gains right, those subs should be okay. The subs are 400 watts RMS apiece, meaning 800 watts RMS to the pair, and if your amplifier does put out 1200 watts RMS at 1 ohm, then you should be okay.
It definitely would help if you posted up what model amplifier you have, to make sure there isn't a better solution.
POTATO!
I have never heard of them, and guessing if they are a crappy off-brand, they won't put out rated.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
That's max power I believe, atleast from what google pulled up. So you really shouldn't hve to worry man. After box rise, you wont be getting the 1200 watts. Just dot clip your subs and you'll be set.
This is the link for the amp.
http://www.titaniumpower.com/Details.aspx?id=2009318121429992124514
Probably didn't come up in hyperlink, don't know how to do on mobile.
Edited by Supercharged DDs
its a titanium power 1200.1 its 1200 at 1 ohm 900 at 2 ohms and 500 at 4 ohms
Phoenix Gold Ti1200.1? The specs sheet says:
Into 4 ohms @ 12.5 Vdc (IASCA/USAC) . . . . . . . . .250 x 1
Into 4 ohms @ 14.4 Vdc . . . . . . . . . . . . . . . . . . . . .600 x 1
Into 2 ohms @ 14.4 Vdc . . . . . . . . . . . . . . . . . . . .1200 x 1
Into 2 ohms @ 14.4 Vdc (Dynamic Power) . . . . . .1400 x 1
Recommended Fuse Size . . . . . . . . . . . . . . . . . .120 Amps
Minimum Load . . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 ohm
POTATO!
