mnrookie Posted April 27, 2011 Report Posted April 27, 2011 I have 2 15" cvx, dual 4 ohm. Wired to 1 ohm, with an audioque 2200d. The gain is barely turned up lpf is around 45-50. Subsonic is turned all the way down, yet when I turn my volume up to about 25 and turn the bass knob just slightly passed 1/4 of the way the clipping light goes crazy and the subs aren't banging all that hard. I don't notice any sound difference when the clipping light pops on, maybe the knob is faulty? Any suggestions how to fix this?
ChevyBoy95 Posted April 27, 2011 Report Posted April 27, 2011 What is barely turned up? And off topic, why is your ssf all the way down(usually set it 5-10hz below tuning)? Lpf is usually around 70-100hz for what most people use... Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
RickyFriery97 Posted April 27, 2011 Report Posted April 27, 2011 if you can get access to a o-scope then set the gains with a o-scope the AQ is a Gain Knob NOT a bass knob and it is pretty accurate 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
n8ball2013 Posted April 27, 2011 Report Posted April 27, 2011 cant be the user blame the equipment. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
ChevyBoy95 Posted April 27, 2011 Report Posted April 27, 2011 cant be the user blame the equipment. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
mnrookie Posted April 27, 2011 Author Report Posted April 27, 2011 It's in a 7 cubic foot sealed box. I don't like my subs hitting high, I like the low tone so I thought setting the lpf lower would elimiate the higher frequencies. Sorry, bass boost is barely turned from min. So the gain knob is 1/4.
ChevyBoy95 Posted April 27, 2011 Report Posted April 27, 2011 Bass boost should be all the way down, don't use it. What are your HU settings(bass primariy)? Well filters are your choice... Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
BlitZ Posted April 27, 2011 Report Posted April 27, 2011 that box is hella big. heres what kicker says... Min Rec Sealed Box Volume (CU. FT.) 1.8 Max Rec Sealed Box Volume (CU. FT.) 5.2 old set up Alpine IDA-X305S Memphis M-Class 4x6" Focal Access 6.5" Hifonics BRZ2100.1D 2x DC Audio Lvl 4 15's Big 3, DR44 Alt, Yellow Top http://www.youtube.com/user/SicNoma003
RickyFriery97 Posted April 27, 2011 Report Posted April 27, 2011 It's in a 7 cubic foot sealed box. I don't like my subs hitting high, I like the low tone so I thought setting the lpf lower would elimiate the higher frequencies. Sorry, bass boost is barely turned from min. So the gain knob is 1/4. off topic: if you like lows then build a ported box tuned to 30-32 hz about 10 cubes after port, sub, and bracing disp. with about 120-150 square inches of port 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
RickyFriery97 Posted April 27, 2011 Report Posted April 27, 2011 that box is hella big. heres what kicker says... Min Rec Sealed Box Volume (CU. FT.) 1.8 Max Rec Sealed Box Volume (CU. FT.) 5.2 its still within specs.. its two 15" cvxs 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
