Looks good to me.
i see u use knu 1/0 on the cresendo 3k. that amp calls for a 300 amp fuse when your power wire only supports 250 amps. you think u losing a lot of power?
2 Runs brother.
i thought it only had 1 1/0 gauge input?
Car: 2002 Buick Regal
Wiring: Knu Kolossus 1/0 + JL 4 Gauge
Big 3: Stinger HPM 1/0
Alternator: Stock 135 Amp
Batterys: Optima RedTop (Hood) XS D3100 (Trunk)
HeadUnit: Pioneer DEH-4200UB
Subs: (2) AQ HDC3 12's
Sub Amp: AQ 2200D
Sub Box: 4.6 Cubes @ 36hz
Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's
Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25"
Speaker Amp: AQ4x90
Sound Dampener : 75 Ft Fatmat
Looks good to me.
2 Runs brother.
It does but i have two runs from front to back and 8" run from rear batt to amp No issues at all.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
Looks good to me.
2 Runs brother.
oh i see, so the less distance of the 1/0 ran the more power? so what do you think you get amperage wise with 1/0 8" length?
Sub Amp: AQ 2200D
Speaker Amp: AQ4x90
Not really sure, I do know that 3KWp stays cool doesn't get hot and my voltage sits rite around 13.9/14.2 so up to this point i haven't had any issues at all with my electrical. looking to get a third batt in the back soon tho as a matter of fact i have another 5100 on order when this one comes in i will be hitting up tool maker to order some custom terminals for the Crescendo.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
im about to do a second battery as well and im curious after seein the diagram do you need to ground the rear battery to chassis?
Heck yes you do. you cant just set a battery there with power going in to it and not be ground. without it being ground you would only be running the system on the front battery.
Bang em if you got em
You should def have two fuses between the batteries like you do in the diagram. And also like mentioned above I wouldn't mix two different types of batteries together. But if you do you should use a battery isolator so that one battery doesn't drain the other one.
  • Who's Online   1 Member, 0 Anonymous, 1604 Guests (See full list)
