Jmoney2544 Posted April 28, 2011 Report Posted April 28, 2011 Ok,I hear both the aq2200d and the Rf 2500-BDCP are both great amps (not choosing between them just example) I hear the 2200 can go up to 2500 watts on good electrical but it has a 200 amp fuse the RF can go up to 3000 watts and has a 300 amp fuse which is normal. how can the Aq do 2500 watts on 200 amps? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
__d_a_v_i_d__ Posted April 28, 2011 Report Posted April 28, 2011 0.5? and higher voltage? just cuss they have those fuse doesnt mean they pull only 200 amps... its give or take. Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
dwright27 Posted April 28, 2011 Report Posted April 28, 2011 ANL fuses cab generally hold double there rated amperage 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
Jmoney2544 Posted April 28, 2011 Author Report Posted April 28, 2011 ANL fuses cab generally hold double there rated amperage so what the point of even having a fuse if they do double? Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
dwright27 Posted April 28, 2011 Report Posted April 28, 2011 Not saying they do I will, but generally the reason is when you have a short in between your battery and amp it protects the amp and battery which sometime can be a 5 - 600 amp ahort 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
D-train-13k Posted April 28, 2011 Report Posted April 28, 2011 that makes sense. if the electricity is flowing controllably it will not have as much resistance like a comparison would be if there were 500 motorcycles on the road all going to the same place and they went in a double file line in the road it would be smoother. but with a short itd be like all of them weaving in and out of each other running each other over and shit. ^forgive me if im wrong but that seemed like a clever comparison A for effort The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Jmoney2544 Posted April 28, 2011 Author Report Posted April 28, 2011 that makes sense. if the electricity is flowing controllably it will not have as much resistance like a comparison would be if there were 500 motorcycles on the road all going to the same place and they went in a double file line in the road it would be smoother. but with a short itd be like all of them weaving in and out of each other running each other over and shit. ^forgive me if im wrong but that seemed like a clever comparison A for effort thanks for the input! a+ Car: 2002 Buick Regal Wiring: Knu Kolossus 1/0 + JL 4 Gauge Big 3: Stinger HPM 1/0 Alternator: Stock 135 Amp Batterys: Optima RedTop (Hood) XS D3100 (Trunk) HeadUnit: Pioneer DEH-4200UB Subs: (2) AQ HDC3 12's Sub Amp: AQ 2200D Sub Box: 4.6 Cubes @ 36hz Mids & Highs: (Front) Rockford Fosgate Power T1693 3-Way 6x9's Mids & Highs: (Rear ) Rockford Fosgate Power T152S 2-Way Component 5.25" Speaker Amp: AQ4x90 Sound Dampener : 75 Ft Fatmat
D-train-13k Posted April 28, 2011 Report Posted April 28, 2011 that makes sense. if the electricity is flowing controllably it will not have as much resistance like a comparison would be if there were 500 motorcycles on the road all going to the same place and they went in a double file line in the road it would be smoother. but with a short itd be like all of them weaving in and out of each other running each other over and shit. ^forgive me if im wrong but that seemed like a clever comparison A for effort thanks for the input! a+ The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
kirill007 Posted April 28, 2011 Report Posted April 28, 2011 Not saying they do I will, but generally the reason is when you have a short in between your battery and amp it protects the amp and battery which sometime can be a 5 - 600 amp ahort In a short the amperage rises to infinity. Efficiency is the key. Audioque=class D amps which are generally more efficient. RF=class AB amp which are generally a bit less efficient then class d amps. And just because the fuse is a bit larger that doesn't means it will put out as many watts as the fuse can handle. Since they don't make 270amp fuses, or atleast they are not standard. Thinking is the root of all problems... You ALWAYS get what you pay for.
