probably trans, but it might be the shifter. only way to tell is to actually go look at at it.
2 12" memphis mojo mojo12d4
hifonics brutus bxi 2610D
1/0 power wire
4 gauge speaker wire
ddm tuning 8000k 35w hids
C&D technologies battery (100 ah)
custom box tuned to around 45hz(designed buy fritosaregood)
2010 kia forte koup
the shifter. ratchet shifters suck a dick.... it probably just needs to be correctly adjusted on the trans or even fitted better in the floor... anyone that knows how to install one could get that figured out in a few minutes.
Edited by JaM Customs aka mprete
My dad and i have a 67 firebird with a tci th350. We have had one problem with it was the s clip holding the linkage while you go through gears internally, so we had to drop the pan and crossmember but it was more time consuming than anything and it was a few dollars in parts. And if it was this you would be stuck in a gear. Thats the only somewhat major problem, but i cant tell you how many times we've been under there adjusting the linkage. And thats just a pain in the ass but somewhat easy fix. And you will know if thats the problem because the shifter wont line up with the gears that you chose, and if may feel loose your you'll have to push the shifter to get it into park
Kenwood kdc-x794
Boston Acoustics S60 components, S65 Coaxials
Jl J2-320.4
Sundown Audio Sae1200d
2 Sundown SA-12's D4
Car Quest NGT Extreme Upfront
Shuriken BT-60 inback
Big3
All Knu Konceptz wire
