CJ18 Posted April 30, 2011 Report Posted April 30, 2011 Not tryin to be a dick. There have been about a dozen of these threads since audio savings dropped the price on the warhorse and everyone thinks they are an expert on the amp when they truly know nothing about the way it functions. ^^^^^dont be such a dick man. Just a simple question with a simple answer no need to get all crazy about it. Thanks to all that answered I will just stick with getting a PB5K for now
MaliBOOM Posted May 1, 2011 Author Report Posted May 1, 2011 Understandable...... However my buddy said I could hook this up with 8 dual 4s www.TheAutoSkin.com MaliBOOM v2"2010 Bagged Malibu on 20s"<< click here<<< Excursion on 42s Build log<<Click here<<< Instagram-@theAutoSkinRyan @TheAutoSkin Owner of The Auto Skin
cc_audio Posted May 1, 2011 Report Posted May 1, 2011 You can, its actually pretty simple. Have you even looked at the manual yet? Read the manual, you pick up the basic understanding of how it works. Then look at the woofer diagram, its very easy to go from one, see how it works. Than to two woofers, than the four and its easy to figure out how to wire 8 up. Just gotta look dude. There are dumbasses that assume the warhorse is just another amp and then there are dumbasses who think the amp is from mars and far too complicated to use. Just read the damn manual, and if you have the slightest understanding of ohm loads you'll figure it out just fine. Jeeze! It's all gone! The Celica Build Feedback If I buy something from you, DO NOT USE FEDEX!
Berto Posted May 1, 2011 Report Posted May 1, 2011 The thing with the Warhorse is that you don't really focus on amount of subs, it's all about the amount of coils. 1 sub usually = 2 coils which = 1 coil per input on the Warhorse. It HAS to be done that way. And technically you can have a min of 2ohms per side. So: 1 sub = dual 2. 2ohms on left input, 2ohms on right input. 2 subs = dual 1ohm or 4ohm. 2ohms on left input, 2ohms on right input. And so on, and so on. TEAM FLEX ISSUES Car: 1985 Oldsmobile Delta 88 Royal 24" Rims HU: 7" Carputer, Planet Audio EQ, iPhone. Coax: T3 Audio 4" speakers Subs: 2x 18" T3 Audio TSNS (walled) Sub Amp: DC 9k SOON TO COME T3 Audio 6x9s MB Quarts 6.5" comp set MAYBE ADDED 2nd DC 9k
CJ18 Posted May 1, 2011 Report Posted May 1, 2011 You can, its actually pretty simple. Have you even looked at the manual yet? Read the manual, you pick up the basic understanding of how it works. Then look at the woofer diagram, its very easy to go from one, see how it works. Than to two woofers, than the four and its easy to figure out how to wire 8 up. Just gotta look dude. There are dumbasses that assume the warhorse is just another amp and then there are dumbasses who think the amp is from mars and far too complicated to use. Just read the damn manual, and if you have the slightest understanding of ohm loads you'll figure it out just fine. Jeeze! Trust me it all seems simple until you actually have to wire the subs. 2 subs is easy but once you get to 4 subs the wiring just turns into a huge mess and it is really hard to keep track of what wire goes where. Best advice I can give is to get 4 differ colors of 8ga speaker wire and use a different color for each coil + and -. So it would look something like this: Coil 1 + =red wire Coil 1 - =black wire Coil 2 + =blue wire Coil 2 - +white wire Something like that will make it much easier to keep track of what wire goes where.
Sanitarium Posted May 1, 2011 Report Posted May 1, 2011 Alright so instead of both coils working together to push the sub then pull the sub. They only have 50% duty cycle while the other is dead weight for that 50% cycle effectively altering the T/S of the sub(s). Unless I missed my mark on this, no thanks.
CJ18 Posted May 1, 2011 Report Posted May 1, 2011 I spent almost 2 years trying figure this damn thing out and I finally just gave up and sold mine and am going to buy normal amplifiers that I know how to properly scope the gains and set correctly. For me this is a fucking bad ass amp but there is just way too much to it to understand to be able to get the full potential out of it. Here is my recommendation for who should run a warhorse. hardcore competitor that knows EXACTLY what they are doing and understands how the amp functions---- yes buy this amp it can put out massive power for a VERY good price. Average daily joe----- STAY AWAY!!! Invest in a good normal mono block amp i.e. DC, Sundown, Rockford, AQ and invest in a good oscope and learn what clean power is and how to properly achieve this by tuning your entire system with the oscope.
dblovah51 Posted May 1, 2011 Report Posted May 1, 2011 Is it possible? I just heard of a guy that ran his at .7 but I thought or heard it would protect at anything under 2. Someone know da hax??? both of mines is at 1ohm and works fine..for now but it should b okay with the right supply! 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
korey_hofer Posted May 1, 2011 Report Posted May 1, 2011 if you have the cash to buy another or just don't care go for it. I'd try it previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
dblovah51 Posted May 1, 2011 Report Posted May 1, 2011 if i knew what i know now i would have stayed away from that amplifier in the first place! but i think itll b sold pretty soon for some SD OR STETSOM where it wouldnt take me close to an hour to wire 4 subs 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
