SPLVan Posted April 30, 2011 Report Posted April 30, 2011 In my new build im gonna be running a 800w 4ch amp and a 1000wRMS monoblock amp. i currently have a middle of the road battery under the hood. should i get another battery and put it in the back? and if i do. i dont think ill be getting a XS or kinetic battery unless i can find one under $100. so would a brand new battery with about 650 cold cranking amps do the job? Thanks! 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
That1Kid Posted April 30, 2011 Report Posted April 30, 2011 Good battery up-front and big 3. You would be fine with just this. -98' Ford Expedition (Rest in Peace) -AVH-P3300BT -Crescendo BC5500 -4 18" DC m2 Level 3.
KnockinthaStreetzof608 Posted April 30, 2011 Report Posted April 30, 2011 c&d battery might be in your budget CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED!
SPLVan Posted April 30, 2011 Author Report Posted April 30, 2011 Good battery up-front and big 3. You would be fine with just this. And by good battery do you mean a XS or something along those lines. Or the average one i mentioned.. 1999 Dodge Caravan [TrashMobile] 8ga Power/Ground AudioPipe APSM-1300 (subs) Scosche 550 (mids/highs) Boss 735UA Headunit (2)Hifonics HFi12D4 Still Under Major Construction.. My Build
bumonskateboard6 Posted May 2, 2011 Report Posted May 2, 2011 Good battery would be XS. What amps are you running? Some are more current hungry than others Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
