:( I think many are failing to see that my subs are inverted, thus I can't really fry my subs or roast them, because I will smell it right away. Also feel that not everyone is reading everything, i said they smelled after a while at full tilt, Took them out then put back in, played over full tilt without smelling anything, thus why I am so stuck on that the pressure inside the box from heating and cooling did it.
Here's what you need to do.. have pen and paper ready. Note the temp, volume, and song you're playing when it happens.
Do it over and over. I'm willing to bet you find it's only specific songs that do it, but I can't b sure because there's just not enough info. Where you located? (No locations on mobile)
Need an install? Hit me up.
[email protected]
lol, so...are the two headunits the exact same?
I have a playlist on my ipod of songs that hit the best on my set up, I played the same songs before and after I took out the subs and put thee back in, each song before I did it smelled, each song after I did it didn't smell. Als what do you mean the 2 HU? I never mentioned another HU.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Then another issue I'm wondering is if you are rubbing since you're inverted. Make damn sure that each sub is centered exactly. That is another thing that will stink up a sub quickly.
[email protected]
I repeat you should never smell your sub after break in your cooking it to death, even if the power is clean it could still be to much for the subs
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
I don't know what you mean by rubbibg, but the subs are pretty damn centered, when I had them in normal the JBL symbol looked pretty centered to me.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
If it's not centered, the surround will rub or the cut out will prevent the sub from moving causing heat to build up quickly. Did you smell both subs individually?
If you have answers for this and insist you did it correctly, then listen to Korey.
[email protected]
are thay single voice coil or dual if there dual and your hooking them up to only one set of voice coils that can cause it to smell stop you will toest the woofer need to hook up both sets of coils
I get what your saying I will check to make sure, also on what your saying korey, I haven't smelt anything since taking them out and puting them back on. Along the power, they can't be overpowering my subs since they are 260 watt RMS, and this amp is only a 250 watt 4 channel alpine, while my MTX was putting out 425 bridged.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
I bet you fixed it. And I'd put money on it that only one of them was smelling badly. Another member came over to my house just the other day with the exact same problem.
[email protected]
